transmission swap wiring
im looking at ejoner's transmission swap write up and its really damn good and i get everything except 2 things
do you lengthen the wire on the harness that leads to the backup light switch on the transmission and lead it into the cabin and attach it to the AT harness?
and also
aside from the auto to manual mount i have to buy from hasport
which other mount do i need?
he says
"You will need the front manual transmission mount. Im not sure if you need the actual rubber mount but I got mine anyway Il let u guys know when it goes in."
whats the rubber mount hes talking about?
this is all he has pictured
and also
he says
I JUST did this I haven't put my new stopper mount on either, just arrived yesterday. I ordered a new one from majestic Honda, wasn't too bad of a price either...
Yes that piece is different on a manual, that one wont line up with the transmission and still fit in the same spot for the front stopper mount.
You need the bracket from a Manual transmission, I think majestic honda has them without bolts for 23 before shipping. I bought a bunch of other bolts and stuff but my total was $65 shipped.
I recommend making a checklist of all the bolts and such you will be missing and just order it all at once to save on shipping and stuff. I ended up buying more than I needed but it made putting things in so much easier when you know you have the right bolts and they are all new.
can anyone supply me with the part number for this piece and the rubber thing that goes along with it?
so i need this thing right?
http://cgi.ebay.com/ebaymotors...36872
Modified by nomoshing at 3:39 PM 8/23/2008
top left black thing = trans
top red wire = backup light wires from harness
red wire from trans = backup light plug on trans
black thing on bottom = auto shifter
blue thing = plug from after you remove AT shifter
do you run wires like this for the backup light switch to work?
Ok take out the AT shifter completely, dont need anything off of it.
Run two wires from the middle bottom two pins on the original harness plug to the clutch pin. Then run two wires from the top two pins to the reverse switch on the top of the transmission.
When you push in the clutch it connects the clutch pin and allows your starter to work.
When you put it in reverse it connects the two reverse wires together making the reverse lights light up.
Davis Photography
personally I wouldn't worry at all about wiring in the clutch safety switch. I skipped out and haven't had any problems at all. You just need to be cautious and remember about that.
probably just like any car with 5sp
weeeeee
i been thinking maybe i should do the swap and do a more detailed writeup because damn
there are good writeups there but theyre kinda fragmented
weeeeee
Davis Photography
thats all you have to remember. It would lurch forward as its trying to start, possibly lurching into a car/pole in front of you. = bad deal.
unlike if you had the switch wired, it wouldn't even turn over until the switch is activated.
Then forget one day lol... That'd be an easy to get part from junkyard/pull a part type place since pretty much any honda has those same type switches, just cut the wires and unscrew it, YOINK!
my primary goal is 2 make my civic dx 93 run but i currently ran into sum wire harness issues.
I swapped my d15 b7 engine from a AT into a MT, so do i need 2 change the indash harness to a manual one??
Seagull Management
Re: (byjl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byjl »</TD></TR><TR><TD CLASS="quote">my primary goal is 2 make my civic dx 93 run but i currently ran into sum wire harness issues.
I swapped my d15 b7 engine from a AT into a MT, so do i need 2 change the indash harness to a manual one?? </TD></TR></TABLE>
You don't have to swap the wiring harness, you just have to make a few modifications to it. I made this thread on wiring up the starting circuit, the right way. https://honda-tech.com/zerothread?id=2348557 Take the reverse light wiring from any auto to manual 5th gen swap guide.
stackz
11-15-2006 01:04 PM
