transmission help!!!! B16 cable
i have a b16 cable with a hole on the casing
either i need to replace it or i was wondering if i can use those internals and put it into a hydro casing?? thus making "cable to hydro"
if anyone has a casing for sale le tme know please!!!!
Re: transmission help!!!! B16 cable
What caused the hole in the casing? If it was the internals then why swap them over? And I take it you did a cable to hydro swap already, if so it might be time to just go for a hydro unit.
Seagull Management
Cable B16 trannys as far as I know are all small spline (like '90 - '91 Integras), you can't swap the guts into a hydro case ('92 - '93 Integra YS1 transmissions you can) I presume the hole was caused by the stock diff grenading?
Damage was done while driving, hit a center divider gears seem ok but I also haven't gotten the tie to open it...
DraginTeg93
02-08-2007 05:33 PM
