transmission grinding
Old 05-08-2006, 06:36 AM
redsled00's Avatar
Default transmission grinding
My transmission is grinding. I jacked up the car and spinned the wheels and the grinding is coming from where the axels meet the tranny. Does this mean a rebuild is in order? Shifting gears is normal but when I coast in neutral I can hear it grind. Anyone know if it's the axels or tranny. No clicking sounds and the rubber is still good on the axels thanks.
Old 05-08-2006, 02:37 PM
redsled00's Avatar
Default Re: transmission grinding (redsled00)
anybody?
Old 05-08-2006, 02:42 PM
postman's Avatar
maybe a bad differential
Old 05-11-2006, 01:44 PM
KRTRACING's Avatar
Default Re: transmission grinding (postman)
i have a 99 si and i just went through the same problem. I took it to a tranny shop and they said my transmission was just **** inside because i race. When i rotated the tire it was a knocking in differential side and you could feel something in tranny when rotating the tire... so i hope for your sake that its not that... good luck man...
Old 05-11-2006, 02:43 PM
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
check your bearings, they might be inhibiting the axles from turning
Old 05-16-2006, 09:19 AM
redsled00's Avatar
Default Re: transmission grinding (KRTRACING)
So did you end up rebuilding the tranny and differential. If so about how much is that? And what bearings should I check. I know it's not the wheel bearings since the sound is isolated to where the axel and tranny meet. Sounds like I have to rebuild everything.
turbo-crx
11-11-2008 06:48 PM
mikes 95 integra
02-25-2008 06:36 AM
Menace2Society
05-29-2007 02:52 PM
-tc-
10-25-2005 07:44 AM
CivicNewbie
07-31-2003 08:58 PM
Quick Reply: transmission grinding
