transmission fluid
Old 12-17-2006, 10:56 AM
globy123's Avatar
Default transmission fluid
Hi. I have a 99 Honda Civic SE which I bought about a year ago and now has 134000km. I don't think the previous owner changed the tranny fluid at all and I want to change the fluid now. I'm not sure if I should do it because I heard that if you don't change it regularly then you might have problems with it if you decide to change it later on. Is this true? I have no problems with tranny accept in cold days it makes a click noise when I shift to 2nd gear. In the car manual it says to change tranny fluid at 144km in normal conditions. Anyone has any suggestions? Oh...also do you think I should go with the genuine Honda fluid or is there a particular brand that's better than Honda for my condition?
Old 12-17-2006, 10:59 AM
POE
POE's Avatar
im a pretty big fan of the genuine Honda fluid..
Old 12-17-2006, 12:21 PM
B18CivicEH2's Avatar
Default Re: transmission fluid (globy123)
just change it....i would go for the Honda fluid as well
if you need help on doing it yourself...heres a link on how to do it..
if you sroll down to the bottom of the page, it'll show you which is the drain plug....but to put the fluid back in, i usually remove the sensor on the tranny and do it from there....
https://honda-tech.com/zerothread?id=851521
Old 12-17-2006, 12:30 PM
bmoua's Avatar
use honda fluid, though i used 5w30 motor oil in mines and works okay. theres alot of debate on using reg. motor oil or honda fluid, but its your choice.
Old 12-17-2006, 12:33 PM
ballerchild's Avatar
go ahead and change it with Honda MTF.
Old 12-17-2006, 02:08 PM
mr_nemesis2003's Avatar
what about using one quart of gm synchromesh fm, and the rest of gm synchromesh
Old 12-17-2006, 02:19 PM
globy123's Avatar
Default Re: (mr_nemesis2003)
Alright...thank you guys...I'm going to change it at a Honda dealer this week.
Old 12-17-2006, 02:24 PM
EG2Driver's Avatar
Default Re: (globy123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globy123 &raquo;</TD></TR><TR><TD CLASS="quote">Alright...thank you guys...I'm going to change it at a Honda dealer this week.</TD></TR></TABLE>
good man
Engine oil goes in the engine
Tranny oil in the tranny
Old 12-17-2006, 05:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_nemesis2003 &raquo;</TD></TR><TR><TD CLASS="quote">what about using one quart of gm synchromesh fm, and the rest of gm synchromesh</TD></TR></TABLE>
why??
Old 12-17-2006, 07:20 PM
i heard that synchrmesh fm was too thin, so it was better to half and half. But i keep reading mixed reviews. i think i'm gonna do 100% synchromesh fm.
Tmilli55
Honda CR-V & Element
09-26-2018 01:27 PM
CRP
11-05-2017 01:06 PM
mysicivic1991
04-16-2007 09:53 AM
The Phil
03-22-2005 11:09 PM
Brolli007
12-22-2002 12:09 PM
Quick Reply: transmission fluid
