tilton twin disk squeaking and squealing. . .help needed
Old May 18, 2008 | 12:16 AM
building boost's Avatar
Default tilton twin disk squeaking and squealing. . .help needed
i have a bseries tilton oc-11 twin disk w/ 9lb flywheel and hydraulic throwout bearing in my car. whenever i pull off in first gear it makes a squeaking noise from the clutch. i adjusted the pedal and it seems to work perfect. but it only squeaks during the time i come off the clutch to pull off in first and sometimes between shifts it'll squeak.
also i noticed when i'm in second gear and i'm coming to a stop, sometimes i'll just leave it in 2nd but i'll be on the clutch so its as if its in neutral, but i can feel the car jerking occasionally as if its still in gear even though i'm on the clutch.
another thing i noticed is now it makes a squealing noise occasionally when i come off the clutch in first gear.
any help with this would be greatly appreciated. what could these possibly be?
Old May 18, 2008 | 05:36 AM
MARC P's Avatar
Default Re: tilton twin disk squeaking and squealing. . .help needed (building boost)
Did you trim down the bolts on the Pressure Plate, you have to do that on tiltons because they rub on the tranny case.
Marc P
Old May 18, 2008 | 02:09 PM
Default Re: tilton twin disk squeaking and squealing. . .help needed (MARC P)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MARC P &raquo;</TD></TR><TR><TD CLASS="quote">Did you trim down the bolts on the Pressure Plate, you have to do that on tiltons because they rub on the tranny case.
Marc P</TD></TR></TABLE>
nope i didn't do that. i guess i'll pull the tranny to check the bolts, any other info on the squeaking/squealing noises?
Old May 18, 2008 | 02:40 PM
fast2camciv's Avatar
mine squeeks just like you described, ive allways known that to be normal, just like the clanging of the discs when the clutch is engaged.
Old May 18, 2008 | 02:59 PM
I am Ironman's Avatar
Default Re: (fast2camciv)
When ever something squeeks I oil it.
Old May 18, 2008 | 07:57 PM
Default Re: (I am Ironman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast2camciv &raquo;</TD></TR><TR><TD CLASS="quote">mine squeeks just like you described, ive allways known that to be normal, just like the clanging of the discs when the clutch is engaged.</TD></TR></TABLE>
how long have you been driving like this?
Old May 18, 2008 | 07:58 PM
vtekthis's Avatar
Default Re: (building boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by building boost &raquo;</TD></TR><TR><TD CLASS="quote">
how long have you been driving like this?</TD></TR></TABLE>
forever, mine has done this for years, as for the car jerking, adjust the pedel out some...
Old May 18, 2008 | 08:02 PM
Default Re: (vtekthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">
forever, mine has done this for years, as for the car jerking, adjust the pedel out some...</TD></TR></TABLE>
much appreciated. thanks.
Old May 18, 2008 | 08:24 PM
since last summer, ive put around 4k on the car already, and the clutch has been doing it since day one....i read on here about people hearing similiar sounds, like i said as far as i know, its normal.
Old May 18, 2008 | 08:59 PM
since last summer, ive put around 4k on the car already, and the clutch has been doing it since day one....i read on here about people hearing similiar sounds, like i said as far as i know, its normal.</TD></TR></TABLE>
thanks for the info. i'm just going to raise the pedal and i guess get used to it. . .
Old May 18, 2008 | 09:18 PM
GT35R_EF's Avatar
Make mine whatever you want
I've seen this same noise on a high horsepower RX-7 w/ a twin disk clutch, squeals and does all the same stuff you said, and when I asked, the builder/owner said it was completely normal. Don't know exactly if it's same circumstances but sounds like it might be ok.
Lenne
Transmission & Drivetrain
Aug 4, 2011 03:28 PM
velisma
16
Jun 14, 2010 08:37 AM
sencarus
Jul 4, 2006 12:47 PM
oinkus
Apr 19, 2005 05:06 PM
People_Mover
Mar 16, 2003 12:42 PM
