Is transmission bracket mount really necessary? PIX Inside
the car is a eg hatch with b16a and b16a tranny swap
after i have done the swap.i dont install that bracket (#15 and #12 and #19 show in the pic below)
the reason i dont install it back on is because one of my friends said that bracket is not really necessary.i thought it is there for a reason otherwise honda would not have designed it.
so.do u guys have it installed or it is not really necessary and what does that backet do acutally?cause the car is already got a tranny mount.
and also i dont install the ac bracket side either.(#18 and #14)
Re: Is transmission bracket mount really necessary? PIX Inside (crazyguy)
They are Tourque Mounts and yes you need them. They help support the engine and not let it move under heavy loads back and forth.
I love playing Jenga with my Civic. Just keep removing stuff until the engine falls out. When it does, then you'll know not to remove the last piece that you did.
What kind if logic are you using over there anyway? You already thought it was there for a reason otherwise Honda wouldn't have designed it, but you go ahead and decide against using it anyway? I see.
Re: Is transmission bracket mount really necessary? PIX Inside (EE_Chris)
The only reason to take off those mounts/brackets is if your going to being using solid mounts. If your not i suggest putting them on.
Hatch_Kid
13
12-31-2012 06:22 AM
Boosted_JDM
04-09-2007 03:45 PM
XkjeldorX
06-21-2006 01:49 PM
