Transimission Problem
as i was driving i herd a pop and white smoke came from the exsahst and the engine. ever since then when i step on the gas it dont move. also all the trasmission fluid keeps runing out when you put it in. cant see where but i though it might be the rear main seal. give me some advise! thx
-Josh
edit: this is my automatic not my manual
Modified by Honda V-Tec at 10:23 PM 2/24/2005
-Josh
Re: Transimission Problem (Honda V-Tec)
try your looking for vacuum lines coming from your engine to your tranny. i'm not sure about the honda auto but with gm there is a vacuum modulator that connects to the engine to cause the tranny to downshift under load.
Re: Transimission Problem (baseballinmyass)
do you mean the fluids GONE? or it's dripping? Also a bang and white smoke is never good...probably not tranny related dude Check for compression cuz you MAY have blew something in your motor...ie bent valves, blew piston.
Also what type of vehicle/motor?
Re: Transimission Problem (hasback-01)
that is why i said i'm not sure and i was just telling to look for a vacuum line becuase that is what his problem souned like ie leaking tranny fluid, huge clouds of smoke and car wont move.
the engine runs fine i just cant go anywhere , when i put the tranny fluid in it drains out like water. cant see where
edit: when you put it into gear it jumps like your about to go then you lose all of the fluid
edit: just contiunes to rev
Modified by Honda V-Tec at 8:09 PM 2/24/2005
hmmm.... i wonder if that's your torque converter. that's what it sounds like also sounds like an axle or your diiferental. man it seems like your in a heap of trouble.
Re: Transimission Problem (civicboisi)
axles are fine , i have everything tak'n apart from the tranny, everything but this one square bolt i cant take off on the mount. i think ill just cut it off and buy a new one. ill drop the tranny replace the rear main seal and see if this fixes the fluid leak. ill take a look at what i can see inside the transmission.
edit: in your opion could it be the seal? will the tranny go without fluid?
the rear main seal has noting to do with tranny fluid. the rear main seals the crankcase at the at flywheel/oil pan from engine oil leaking out. if your leaking tranny fluid why are you looking at the rear main?
Re: Transimission Problem (BauleyCivic)
would a broken axle cause white smoke to exit the vehical and engine?
edit: the engine would spin from an axle but no smoke would of been present. remeber the tranny fluid leaks out when you put it into gear
lol , im josh my dads name was mike , i know most anything about cars but never really came into a tranny problem i had to fix. always gave my dad hard jobs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda V-Tec »</TD></TR><TR><TD CLASS="quote">would a broken axle cause white smoke to exit the vehical and engine?
edit: the engine would spin from an axle but no smoke would of been present. remeber the tranny fluid leaks out when you put it into gear</TD></TR></TABLE>
haven't changed many axles huh?
Honda V-Tec
02-27-2005 11:43 AM
