tranny leaking fluid
i jsut dropped a 91 itegra ls motor into my 92 civic hatch and now its leaking really fluid
around the bottom of where the bell housing of the trasmition meets the back half of the tranny so i watend to know if anyone knew what i possibly could be ... or just why its doin that .... thanx for the help
Re: tranny leaking fluid (street sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street sleeper »</TD></TR><TR><TD CLASS="quote">are you sure it was leaking from that spot, or gould it have dripped down from the fill hole? </TD></TR></TABLE>
lol
For real...make sure you know what it is actually coming from before you rip that **** part? So did you use the LS tranny too?
I had a tranny leak for like 3 months...and I couldn't ******* figure WHERE that **** was coming from that it would leak soo much out in one day. Come to find out....one of the return lines to the tranny.....well where you bolt it down...there was just a little bit of grit that i guess i didnt sand down or clean off after the swap and when i tightened it down...it let fluid in the tranny so it worked...but i never noticed that from that minute gap tranny fluid was just draining out and runing down the side ...so the WHOLE time I was thinking it was my input shaft seals. I had the car up like 3 different times...had 2 other buddies down there trying to help me find WHERE it would come from.
Try and clean it to get all the oil and dirt off....and then turn the car on....for like 5 to 10 min and then look...put some cardboard down to try and look to see in which area it is coming from...go from there. good luck
lol
crazyguy
08-25-2007 09:46 AM
civicmon
10
11-17-2003 03:54 PM
