Tranny Help ASAP PLEASEEEE
I Installed a act 6puck and heady duty PP and the next day i was driving and down
shifted from 5th to 4th and my RPM's flew passed 8k and when I gave it gas all I
heard was grinding and my car wouldnt move. So now im taking the trannyoff and
I have every bolt off that holds the tranny on and something is holding the
tranny on the inside I have been prying the last 4 days it will no come apart.
Someone said the input shaft could be stuck the the PP but I have never had this
prob before what should I do. This is on a B16A (Sir 2)
Re: Tranny Help ASAP PLEASEEEE (D16z6Coupe)
You will need the Helms if you are taking the tranny apart. Don't even think of it without the Helms. The Helms will tell you the one thing that you need to do to get the tranny case pieces apart.
Re: Tranny Help ASAP PLEASEEEE (Bnjmn)
Im trying to get the tranny off the motor not take the tranny apart yet the prolbem is that the tranny will not come off the motor.
Re: (D16z6Coupe)
sounds like a dowel (or whatever they are called) is stuck. I cant really imagine that it would hold the whole tranny up on its own. I guess the only advice i have for you is while prying make sure you DO keep the level so you do not bend/break/jam the shaft if that isnt your problem to begin. Good luck!
-Bryan-
-Bryan-
If the clutch is fucked you should be able to remove the 6 pressure plate bolts through the starter hole. Remove all six of them and it should come apart.
Solbros Owns Me
Re: (D16z6Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16z6Coupe »</TD></TR><TR><TD CLASS="quote">Good idea about taking the bolts out through the starter. Finally a idea hell yes</TD></TR></TABLE>
haha, don't you love it when people respond like you're just the biggest idiot
This does not seem like a fun situation though....
last time I had a problem like this, I actually broke my shift fork
duneracer69
11-03-2005 05:06 PM
