Tranny/Clutch Problem- who can guess what it is first?
Well, upon driving somewhat spirited tonight, my car wouldn't go into 3rd or 4th at high RPM and I had to go directly into 5th and cruise (5th was uncharacteristically easy to go into I might add). At the next stoplight it barely went into 1st and shuddered pretty violently and did the same going into 2nd. As I went home it progressively got worse (the violent shaking and inability to get into gear). But, it isnt very difficult to get out of gear ? Could it be the pressure plate even though it still disengages, bad clutch, bearing, or warped flywheel? I'm sure someone has an answer before I start tearing **** up There has also been a squeaking noise today and yest. that I couldn't narrow down and am pretty sure aided in this.
I'll post this in the tech forum too, thanks guys.
Cliffnotes: Gunning it doesnt wanna go into 3rd or 4th, then violently shakes after struggling to get into 1st and 2nd. T
[Modified by ill phil, 12:46 AM 11/14/2002]
1 Post
Re: Tranny/Clutch Problem- who can guess what it is first? (ill phil)
when the car is off, does it go into gears? sounds like a bad clutch but I kinda had the same problem and it ended up being the shift selector on the tranny.
Re: Tranny/Clutch Problem- who can guess what it is first? (eg_nezay)
Yeah car goes into gear fine with the car off, but with the car on I push in the clutch and the starts shaking.
Yeah.... Thanks for the input guys. Any other experiences and suggestions welcome.
Re: Tranny/Clutch Problem- who can guess what it is first? (Esone3)
Gear oil seems to be fine, and clutch fluid is normal. I just read a post by someone with similar problems, squeaking, trouble going into gear and shaking going into gear and turns out he had a broken clutch plate. So tomorrow I will more than like pull my tranny and look for a new clutch.
Any opinions on Exedy Organic Racing Clutch? $265 shipped from Clutch City Online. I'll go do some searching on it.
jdmej814
07-26-2009 05:05 AM
RTW DC2R
09-05-2003 07:36 AM
