Tire Rubbing EJ1
Tire Rubbing EJ1
so my tire rubs in the front on my ej im lower on skunk2s and im just running ls mesh wheels. should i camber it more +/-? i believe my camber in the front is is -1.4 something around there it rubs when i turn (even little turn) and if i turn hard it rubs the inside and yes i tired the search first. Thanks
318 Curves, 11 miles
Re: Tire Rubbing EJ1
What's the ride height? What's it rubbing on?
-1.4 is decent camber if you're not more than 2" dropped - you shouldn't be rubbing fender. If you're more than 2", you probably will have to roll fenders or add camber.
Despite popular belief, 2* of camber by itself shouldn't cause abnormal tire wear, provided that everything else is in good alignment. Lots of cars run 2* of camber *stock*... G35s, BMWs, s2Ks. Running that much though, you HAVE to have your toe zeroed or you WILL kill tires FAST.
Anyway, back to the original question. Assuming that you're dropped less than 2" (which I think is what S2s are supposed to put you at), My guess is that you're rubbing the bump in the left front fenderliner, probably more often when you're turning right. If that's the case, you can pull the liner, or punch another hole in it and try to pull it tighter.
tire size??
severity of drop??
sounds like your frickin slammed on some 195/55/15s... which will rub just a bit close to full lock
severity of drop??
Coopa B18c5
01-18-2013 07:58 PM
98savage
Suspension & Brakes
20
10-25-2008 06:31 PM
alacard
Suspension & Brakes
14
12-08-2006 02:35 PM
