time to get a cat and put away the test pipe
92 cx
b16a
right now i have a 2.5 test pipe and a hks hiper cat back 2.25 i just bought a dc jdm 2.5 header and i want to get a cat in 2.5 that bolts on with no modification
ipsracing.com sells a carsound cats but which one would i have to buy to fit my application?
thanks guys
b16a
thanks guys
Re: time to get a cat and put away the test pipe (CiRcUiTsi)
ill borrow one if someone tells me what one to borrow
i know for a fact im not the only one with a eg and a swap so all i need is a few people to tell me what cat thier using and the part # and where they got it from.
Re: time to get a cat and put away the test pipe (one-syk)
hmmm...since you have exhaust that is made for your car, and a swap that came with the car at one point in another country, i would think that a civic cat is going to do you right.
correct me if i am wrong, but i am pretty sure about this one.
one-syk: make sure it is a 2.5 so you won't have to buy that collector!!!
ipsracing sells carsound cats these are the applications they sell:
94-99 gsr
98-01 itr
99-00 civic si
94-00 gs,rs,ls
all of the applacations listed above are 2.5
my question is do any of the above bolt directly between my header and exhaust with no modifications?
94-99 gsr
98-01 itr
99-00 civic si
94-00 gs,rs,ls
I believe an ITR cat should work because it is shorter than a GSR cat. Im running a GSR cat wth my b18c in my hatch, but i have a usdm itr exhaust manifold that im going to put on, and I was told I need to go back to a civic cat because the itr em is longer than the gsr and that civic cat is shorter than the gsr cat.
If puch comes to shove jus get a tape measure and crawl under the car and measure, then email the folksat the sie with your measurement and get the cat that matches your measurement.
Damn, that was long winded
ask ipsracing, or get under the car and measure how long your testpipe is.
also not how many O2 sensors you will need to be on the cat and where.
B HATCH
04-12-2004 02:39 PM
