Thmanx's R-DOT B18C5 project
#76
Re: Thmanx's R-DOT B18C5 project
Yes the brackets are cast iron, but i painted them silver to match the block.
The A/C mount however IS aluminum (a factory optional part) normally its cast Iron aswel.
#77
Its not a dream for me, I honestly dont care. id rather get a old head 5x cheaper and take it to a machine shop to have it restored, especially if you are going to modify it in any way its just a complete waste of money. And you can get a B16 full swap from Japan with decently low miles for that much money... I'm not a fan of B swaps but I'm just saying, full swap vs head... For the price you could also buy a head online and have it fully built in any configuration you want for $1000+.
To OP...your money, your dream, your car...amazing job. I enjoy reading it, I just cringe at the price sheets. Thats a clean, clean, clean motor, lol.
Edit---there is something to be said for building a well built car vs buying someones rigged up type r civic with rot and who knows what.
#78
Wow , amazing job, knowledge, ,really good job,
Can I order the aluminum ac bracket direct from Honda, if yes can you provide a part number or this is jdm part only
also haw connect the bracket to the Ek body ,which motor mount i have to use?
Thanks
Thanks
#79
For the A/C bracket, its a JDM N1 Honda Part.
http://www.inlinefour.com/jdmtypalacmo.html
if you want to use A/C you'll need to drill/tap the threads for the compressor to mount up. (the N1 aluminum bracket has the holes, but no threads)
Once you bolt the aluminum bracket to the block, you can use your standard EK torque mount thats on the bottom of the frame rail.
I mention this in the first part of this video.
#80
New Alternator brackets & Aluminum ITR A/C bracket w/ compressor mountings tapped
Do you have these kind of part numbers do? Thank you
Jap_Spec_Imports
04-16-2008 08:21 PM
B18CXr
04-14-2003 02:15 PM
