Thinner Head Gasket= higher compression ? ? ? ????
Ok I read this in a previous post , and was alittle shocked . I am still learning ins and out of somethings on engines but I know basics . My question is how does changing the head gasket change your compression ? ? ? ? If I changed my head gasket on my d16y8 how much of an increase on compression would there be ? ? Would there be a noticable change in performance when combined with Intake , exhaust and advanced timing etc etc ? ? ? ? ?
Re: Thinner Head Gasket= higher compression ? ? ? ???? (you2envious)
Re: Thinner Head Gasket= higher compression ? ? ? ???? (JV)
i thin an explanation is given on the spoon sports website
[Modified by JDM Dasilva, 10:41 AM 5/26/2002]
Re: Thinner Head Gasket= higher compression ? ? ? ???? (JDM Dasilva)
changing head gasket is same as milling the head closer you get the pistons to the head the higher the compression on the motor
the smaller the combustion chamber is the more compression there is
thinner gasket makes the block and head closer together , thus a smaller comb. chamber
Re: Thinner Head Gasket= higher compression ? ? ? ???? (hybridreams)
(((LIGHT BULB LIGHTS UP)))) Cool I gots it , thanks for the feedback . But if I do this how much might I gain in compression ? Will it be a slightly noticible gain ? ? ? , similiar to the gains seen in a intake or exhaust ?
[Modified by you2envious, 5:29 PM 5/26/2002]
Ivan_JDM_hatch
12
07-13-2007 06:44 PM
changing, compression, comprssion, gain, gasket, gaskets, head, headgasket, higer, higher, honda, make, makes, thin, thinner
