Thinking of buying a 96 civic b18 swap for 3grand
Old 01-12-2013, 05:39 PM
csrt4isdead's Avatar
Default Thinking of buying a 96 civic b18 swap for 3grand
First off let me say I have been on forums for my caliber srt that was totaled a week ago. So from being on forums they tend to have a introduction section but I did not notice one here. If there is one I would gladly post up.
Now I'm new to Honda and I'm interested in the civic but not sure if I'm paying to much as the cars paints faded and some rust. The good part is it has all the paper work. The guys has some parts laying around he will throw in with the right price.
This is the for sale post.
Up for sale is my 1996 Honda Civic Hatchback 5spd. Swapped a B18 full motor in the car out of a 96 Integra. Full swap, and I have the title to which the motor came from. Wired with a 98 civic ex harness, so its plug and play, no hacked wiring. No check engine lights on car. Just passed emissions as well. 150k miles on the body, motor swap has about 115k, fully rebuilt. All work was done by myself in my shop. I'm ASE Certified Tech. I have paperwork for pretty much everything along with receipts and photos of building it all. Title is clean, clear and in my name.
Work/Mods done include:
ACL Race Rod Bearings
ACL Race Main Bearings
ACL Race Thrust Bearings
ARP Rod Bolts
ARP Main Bolts
ARP Flywheel Bolts
ARP Pressure Plate Bolts
ARP Harmonic/Crank Bolt
Integra Type R Oil Pump w/ pick up
ITR Water Pump w/ Timing Belt
Moroso Oil Pan Stud kit
Cam Seals, Crank Seal, Rear Main Seal, Valve Cover Seal, Distributor Seal.
New Distributor Cap, Rotor, NGK Iridium Plugs, NGK Wires
New Axles
Exedy 9lb. Flywheel
Exedy Clutch and Release Bearing
ASR Rear Subframe Brace
Apexi WS Catback Exhaust
Chikara Headers, off car for emissions.
DC One-Piece Strut Tower Bar
Integra Full Size Radiator
EM1 SI Shift Linkage
EM1 Si Front and Rear Sway Bars
EM1 Si Airbox
Civic HX Rims with Snow Tires
Ep3 SI Seats
Jdm EK Amber Clock
Jdm EK Vent Pocket
Currently has HX rims with snow tires
The swap has about 4k miles since the rebuild. What should I do guys?
csrt4isdead is offline
Old 01-12-2013, 08:13 PM
Former User's Avatar
Default Re: Thinking of buying a 96 civic b18 swap for 3grand
There are Member Introduction and Value stickies at the top of this forum - gray highlighted. Please split the text in your first post into two separate posts in those two stickies.
The main forum is designated for technical threads only.
Former User is offline
elhartd
18
11-22-2010 05:35 PM
kajorge
03-24-2010 05:36 AM
dachinkrac3r
01-28-2006 08:43 PM
Hondasaurs
03-26-2003 08:31 PM
Quick Reply: Thinking of buying a 96 civic b18 swap for 3grand
