Manual Window Regulator Repair?
Okay, ive been having a rough time roll my window up lately on my 99 Sedan (drivers side) and today it gave out. I wont be able to find one locally for sure and I already purchased this a year ago secondhand. I opened it up to do repairs but not quite sure how it all works out, any help regarding the internals or at least some photos of an opened regulator?
Re: Manual Window Regulator Repair?
Front or rear?
Be sure to lubricate the rubber side channels with silicone lubricant to prolong the lifespan.
I don't think repair of the sedan-style cable-driven regulator would be easy.
Front driver
Im aware of lubricating, but i took the assemembly apart and it was all off track and the cables popped out.
It looks doable, just hoping somebody may post a picture or guide me as to how theirs looks.
I suppose I forced cranked it to pull up and ended up getting the cable loose from the window track which then loosened the cable in the crank assembly.
Im hoping that if i can get some better visual of a manual driver sedan regulator And/or internals I can fix mine and then make a tutorial or diy fix thread on it.
Any obvious cable fraying or broken parts?
I could be screwed if i did that. The fins for the inner gear are a bit frayed but i suppose something could be done there, i wish i kept my old regulator which my parents had me dump, damnit. I may have repaired it, just put it back together, going to test it
Ah, true true.
Well, I put it together, and cranked it a few times. Seemed good, until I installed it into the car and it broke again.
Apparently, there's a certain positioning for the gear and spindle and the cables which require a certain amount of torque....
Just my luck, somebody posted a Civic part out an hour ago, and I asked him to part out the regulator for $25.
jdmztrane
11
06-23-2010 08:04 PM
strictly.business
15
11-28-2006 11:20 AM
