temp sensor?
Old Jul 9, 2003 | 07:38 AM
mooseknuckle's Avatar
Default temp sensor?
I just got threw a CAI on my DX yesterday. I gotta y8 manifold, and the "temp sensor" (correct me if wrong) goes into the intake tube. While I had my Short ram, I had this sensor inside the tube. So yesterday after the installation, I drilled a hole to in the tube and put the sensor in. Once I started the car to make sure everything was kool. I gotta check engine. The car runs normal, but I dont want this check engine light on.
Question:
1. I've heard if you damage that sensor you need to find a new one at the junk yard because you can't just buy a new one?
2. Do you think it could be something else?
3. WIll it effect the cars performance?
Thanks in advanced.
Drew
Old Jul 9, 2003 | 08:02 AM
monicle's Avatar
Default Re: temp sensor? (mooseknuckle)
well mabe you should see what CEL you are getting first thatll make it easier to tell you whats wrong.
Old Jul 9, 2003 | 09:52 PM
Default Re: temp sensor? (monicle)
After I took the sensor out, my car idled a little better?
Any input?
Old Jul 9, 2003 | 09:56 PM
turbotime's Avatar
im curious about this too. My IAT got ruined by fire and my computer is throwing a CEL for it, wonder if its whats causing my car to idle poorly, and some other odd quirks its been having. Any ideas on this anyone?
Old Jul 9, 2003 | 10:03 PM
Default Re: (turbotime)
I just fixed it. I just disconnected my neg terminal on my battery and the light went off.
I feel like an *** now
I was told that if you blow that sensor your car will run shitty and throw codes. I
was told your car will run real rich. I dont know why my idle was better w/ it off though. It seemed to kick down faster with it off.
Someone has to know the answer to this one.
Drew
tamadrummer1120
Sep 29, 2011 05:56 PM
r.etheridge
Feb 13, 2011 02:59 AM
keilux
21
Feb 15, 2010 05:08 PM
99d-series
May 1, 2009 08:56 AM
Fatty_1775
Jan 26, 2009 10:00 AM
