teg seats into 99 coupe?
Old Mar 20, 2002 | 09:24 PM
miahmouse's Avatar
Default teg seats into 99 coupe?
I know that gsr seats will work, but is there any difference btw 2dr and 4dr integra seats? Aren't the gsr seats the same as all the others(shape and support wise)?? can I use the rear seats from a 4dr??
Old Mar 20, 2002 | 09:28 PM
Mr. Thunderlips's Avatar
Default Re: teg seats into 99 coupe? (miahmouse)
as for the fronts...all integra seats are the same...no difference in RS, LS, GSR, Special Edition...bla bla bla...only diff is some come in leather...4dr rear seats are the only difference...i hear that they bolt in the civic coupe just fine...have you searched on this topic...i know its come up quite a few times this week...
Old Mar 20, 2002 | 09:41 PM
miahmouse's Avatar
Default Re: teg seats into 99 coupe? (ThunderLipps)
Thanks for the info. I tried a search but I guess I'm not typing in the right keywords or something.
Old Mar 21, 2002 | 08:13 AM
cre18's Avatar
i just finished my interior on my 97 hatch. full front and rear 2001 black leather gsr seats. if your going to put the gsr seats in your civic, there are a couple minor mods that need to be done. with the fronts, people always talk about swapping the rails from your civic seats, but i found that it was easier to keep the gsr rails on. the front two bolts will match up fine, but the rears ones won't because the gsr rear right rail is straight instead of bent down and the rear left just doesn't match up at all. here come the mods. bolt in the front two bolts first. then slide the seat forward so you can work on the rear. for the right rear bolt, you need to take a hammer and bend down the rail in order to get the bolt aligned. don't worry you won't break anything. the left rear rail i believe is too long, so what i did was to take a hacksaw and cut the little end bump off, then i was able to put a washer over the rail with the bolt. that way all 4 sides of the seat are anchored securely.
for the rear seats, it might be a little different cause i have a hatch, but i used the gsr seats out of a 2-door. the bench went in with no problems, but the two rear back sections took some more mods. for this to fit perfectly i had to swap the skins, but you may not have to do that. good luck, hope my explanation helps out.
Old Mar 21, 2002 | 08:30 AM
Trey's Avatar
25 Year Member
Default Re: teg seats into 99 coupe? (cre18)
3-door (hatch) teg rears won't fit in a coupe.
You need the 4-door teg rears for it to work correctly......
Old Mar 21, 2002 | 09:59 AM
miahmouse's Avatar
thanks for the mod info. I found a guy that put the 4dr rear in his coupe and trying to get some pics from him. A couple people say that their small, but if they're really that small why would anyone be swapping....thanks again
Old Mar 22, 2002 | 08:40 PM
JL 74's Avatar
4 door non GSR (leather or cloth) front seats are not fully bolstered. I have posted pics before on this to compare.
Also, the rails on the passenger seat is a direct bolt on from GSR to Civic but not the driver. The left side rail needs to be swapped or hammered. I read the post above and I am not sure about the "rear slider" he is talking about.
slick1851
Feb 19, 2010 10:32 PM
EJ2_B16
Mar 25, 2006 01:32 PM
Axemurderer23
Nov 3, 2003 05:11 PM
TurboTeG4
Oct 11, 2002 02:18 PM
