Teg rear sway bar on EK?
Just wondering if anyone knew if I could use a GSR rear sway bar on my EK. It doesn't look like the brackets are the same as the ones for Civic.
Re: Teg rear sway bar on EK? (sniggler316)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniggler316 »</TD></TR><TR><TD CLASS="quote">Just wondering if anyone knew if I could use a GSR rear sway bar on my EK. It doesn't look like the brackets are the same as the ones for Civic.</TD></TR></TABLE>
nope I do not believe you can.
I may be wrong.
So lets wait for the next response.
I may be wrong.
Re: (Eran)
<FONT COLOR="blue">
1) what size is stock EK sedan rear sway?
2) what MM size is itr & jdm itr rear sway bar?
3) what is needed for install? do i have to get matching lca as to what rear sway bar i go with?
</FONT>
</FONT>
1) 13mm
2) 22mm usdm, 23mm jdm
3) em1 d-brackets, em1 endlinks (for ek)** for the smaller bar
7/8" or 22mm D-brackets and em1 endlinks (for ek)** for the itr bars
4) No...you just use ones that have swaybar holes and match chassis (so if ek...any ek rear lca - if eg...integra lca)
if your chassis is eg, use integra endlinks
