tech:D16 INTO CX EG ...HELP!
My boy just brought a 92 cx EG(5 speed) w/o and engine and he has a d16 engine off a auto ex......what does he need to put the d16 auto tranny to make it a stick .....i told him he needs a get a clutch kit and a manual tranny off a ex..or is it not worth it to does this swap and how much money will he be spending?...need some help TECHS ...thanks
Re: tech:D16 INTO CX EG ...HELP! (marked001)
OK ...he has a cx body 5-speed....and he wanna put a d16 Ex engine in but its an auto tranny engine...we wanna know what else is needed to do the swap..
Re: tech:D16 INTO CX EG ...HELP! (cr00klyn718)
don't waste your time swapping to auto. you'll regret it later. you can find a used 5 spd tranny from $50-$250, change the flywheel, and get a new clutch. everything will slide right into place. vtec should be wired in a 92, but if not it's 2 simple wires. i have a 93 cx and dropped a d16. my motor came from an auto. i changed the fly and clutch and had to wire vtec. pretty easy.
Re: tech:D16 INTO CX EG ...HELP! (buster13)
Thank....yes we wanna change the d16 into a manual...not the other way around...how much do u think we gon have to spend...i guess we gonna do it ourself....thanks buster 13...u gotta pics of the car?
Ok If I understand this right you will need to get a tranny $250-300 and a clutch $150-$300 flywheel $50 used. Resurface that bitch!!! and some axles$75 each. bolt trans and motor together then drop it in to car and wire anything if you need to. Then you should be done. simple maybe 6- hour work.Throw the auto away.
[Modified by SoloSol, 4:22 PM 2/28/2002]
Re: tech:D16 INTO CX EG ...HELP! (SoloSol)
i don't know what the prices are out in VA, but i can get an EX tranny w/ 60,000 miles on it for $100 right now over here in WA. and i just picked up both axels for my car w/ 5,000 miles on them for $60 two weeks ago. when we swapped my motor, it took between 4 1/2 - 5 hours. but this was about 4th swap we've done on an EG. the last swap we did just for fun because we were bored.
Daniel_san
18
06-18-2003 02:13 PM
