TDC question....did a search but couldn't find a thing!!!
I did search through recent topics and archives but couldnt find a thing....but anyways I am going to do a leakdown test on an ITR motor that I found. I know how to get TDC on cylinder 1 with the white mark on the pulley, but how do you know when cylinder 2, 3, and 4 is TDC? I know you can shine a light in the cylinder to see when the piston is up but it can either be compression or exhaust and compression is what i'm looking for. TIA!!
Re: TDC question....did a search but couldn't find a thing!!! (Synergy001)
Check the position of the distributor rotor for whether you are on compression or exhaust. for instance, take the #1 cylinder to TDC and look at the distributor rotor. If it is in position to spark the plug for cylinder #1, then you are on the compression stroke. After getting to compression TDC for #1, just follow the pattern around for the other cylinders.
Edit:
You may already know this, but firing order is 1-3-4-2
Set it to compression TDC on #1. Then rotate 180 degrees for TDC on #3, then another 180 for TDC #4, then another 180 for TDC #2
Edit:
Every time the ''up'' label on the cam gear changes a quarter turn, it is a new piston at tdc.
''up'' on top = 1 piston tdc
''up'' on the left = 3 piston tdc
''up'' at bottom = 4 piston tdc
''up'' at right = 2 piston tdc
Like he said 180 turn on the crank each time will do it. This according to Helms manual 180 turn at the crank = 90 at the cam gear.
Hawaiianrr
21
03-23-2012 05:08 PM
street dreams
11-21-2004 02:44 PM
