B17A Compression
I searched, and I can't find this info to save my life.
My 92 GS-R tested 195 accross the board with 214,468 on the clock, but I need to know if that's low, or if it's still in the good.
Thanks in advance!
Thanks in advance!
8:1-8.5:1 compression: 150-170 psi per cylinder
8.5:1~9.5:1 compression: 170-210 psi per cylinder
9.5:1~11:1 compression: 210-275 psi per cylinder
11:1+ compression: 250+ per cylinder (highly depends on cams being used)
Right off of www.evans-tuning.com's website. These are the numbers you want to be in.
It's not so much the actual numbers, but the consistency of the numbers. Unless maybe they're all below 140 or something LOL. Then either you did the testing wrong or something is fatally wrong with the engine.
Well, I finally found some actual numbers, and they state that the motor is supposed to be at 185psi, with a variation of no more than 28psi, and no lower than 134psi.
I'm deffinately happy with 195!
Thanks for the help, guys!
Convert
Jan 28, 2009 05:44 PM
jinn
Apr 21, 2003 03:28 PM
