targa top handle broke!!
Old 11-01-2011, 02:37 PM
andybmuzik's Avatar
Default targa top handle broke!!
my driver side targa top handle broke..i ordered one on ebay but is there a way i can put it on the lock position for the time being without messing up the ridges on the bolt??
Old 01-04-2013, 03:18 PM
VegasTC's Avatar
Default Re: targa top handle broke!!
Mine broke recently, also. Looks like the handle just cracked because it still closes the top enough so it doesn't move around. But, it won't officially lock or turn the light off on the dash. Hoping I don't have to replace the whole locking mechanism. I figure I have to replace the handle either way so I'll start there. Anyone know how to replace a targa top handle? Thanks!
Old 01-05-2013, 02:09 AM
gzes's Avatar
Shouldnt it just pull of. My carbon top os missing both. They are in the glove box broken but my donor has em in great shape
Old 01-07-2013, 05:03 AM
VegasTC's Avatar
It was super easy to remove the handle. There's a little plastic screw cover that comes off, and it's held on with one screw. I bought a new handle on ebay so hoping that's all it will take to fix it, especially considering how many people have said those things break easily. Shoot -- knowing the service center at my local dealership, they would have charged me $500 to do the same repair (they wanted to charge me between $300-600 to replace my radio antenna and screwed up my clock and radio in the process of just looking at it. I STILL have to replace my own antenna AND figure out what they did to screw up the clock and radio because they insist they both spontaneously stopped working and need to be replaced now). After I brought it to them, I found out that this particular dealership service center is very bad about damaging otherwise working parts in order to drum up sales, especially with women.
Old 01-07-2013, 06:35 AM
Lizardslap's Avatar
cost me 40$ for a set of 2 when I dropped my roof and broke both.
Just peal off the little plastic grommet in the middle remove the screw and pop on the new handle and screw it back down
put the broken handle on and vice grip it shut so you only damage the broken handle
Old 08-29-2014, 04:49 PM
jhelmuth's Avatar
I ordered the new handle but I still can't figure out how to replace it.
Old 08-30-2014, 10:00 AM
Pezzil's Avatar
Mine broke as well. I just wrapped a folded up paper towel around it and turned it closed with a pair of pliers.
Old 09-01-2014, 06:58 AM
jhelmuth's Avatar
I bought the new handle. The problem I'm having is the plastic handle broke off the ridged bolt part, and I can't get the ridged part off.
Old 10-07-2014, 05:59 AM
Han Solo 1's Avatar
I'm having the same problem. I bought the car like this, and my new handles just came in, but the ridged bolt part is still on both sides.
Were you able to get them off?
Old 10-07-2014, 06:52 AM
ejv8s10's Avatar
For my Del Sol I made my own handles.
I used 1/4" steel plate and cut it into the shape of the stock latch. I drilled a 1/2" hole where the splined part goes. I welded the spline from my original handle into the hole. Paint it black and never replace a handle again.
Old 10-07-2014, 02:34 PM
yhammer's Avatar
can you post some pics of the handles. I always like to see how others modify and adapt.
Old 10-07-2014, 03:43 PM
crazyhouse2011's Avatar
yes please post pics.
Old 10-13-2014, 05:36 AM
Han Solo 1's Avatar
Well, upon further review, it looks like the moron who had the car before me decided to just use vice grips to unlock the roof instead of buy actual handles.
When I checked again, I actually don't have the ridged part on the screw; it's just the bare metal screw that's mangled because of the vice-grips use. I got new handles, but the ridges won't catch on the screw because they're in really bad shape.
Is there any way to simply replace the screws on the roof locks? Or will I have to buy a new roof?
techmage916
11
04-01-2018 11:22 AM
Mike91204
07-21-2016 01:45 PM
projectx2005
02-04-2008 06:00 AM
Yell00ITR
04-11-2004 09:50 PM
slvrcivic97
07-15-2003 09:10 PM
Quick Reply: targa top handle broke!!
