taking apart tranny...
i already took out all the 14 mm bolts that hold it onto the housing. i split it off of it, but thats as far as it goes, about an inch apart, but its still connected. what did i forget or missing?
Re: taking apart tranny... (95hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatch »</TD></TR><TR><TD CLASS="quote">there was just a thread about this. There is a snap ring that you have to open while you slide the casing off.</TD></TR></TABLE>
hmm thanks...ill search for it.
Re: (crucial si)
https://honda-tech.com/zerothread?id=588544
I think they were talking about my thread.
Enjoy!
go find that magazine, it should still be out.
Enjoy!
Re: (Plan B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plan B »</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/zerothread?id=588544
Enjoy!
go find that magazine, it should still be out.</TD></TR></TABLE>
cool, i read it over...i need to remove the plugs(ie, drain plug etc?)
Enjoy!
Re: (Plan B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plan B »</TD></TR><TR><TD CLASS="quote">yeah, i guess you have to remove the plugs, i pretty much just took out everything.</TD></TR></TABLE>
i just assumed that that is connected to the part of the casing that is coming off...
i have it cracked apart, about an inch but it still wont come apart.
Re: (crucial si)
okay, be sure you've removed the bolts with the little bearings, etc. Then the one on the top side of the case, then separate and pull up on the snap ring in the top of the case.
-Brian
-Brian
Re: (Plan B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plan B »</TD></TR><TR><TD CLASS="quote">okay, be sure you've removed the bolts with the little bearings, etc. Then the one on the top side of the case, then separate and pull up on the snap ring in the top of the case.
-Brian</TD></TR></TABLE>
ok im lost now.....i dunno what youre talking about now..lol..
what little bearings? arethey the allen key bolts?
and i dont see a snap ring...
what side are you considering top..?
Re: (crucial si)
okay
undo this plug on the topside, and within, there is these two little pieces of metal you can see, they are in a grove inside that little hole.
Stick some pliars in there and separate them, and then pull up on the case at the same time, it should come apart.
The bearing bolts, okay, imagine the tranny is still in the car, from the "underside" there are 2 bolts, i think 12 mm, i think, pull them out, there should be a spring with a tiny ball bearing in there with each, put them to the side exactly as you found them.
Then, on the top side, where the upper tranny mount attaches, there is one more bolt, pull it out, it's 12 or 14 mm also,
You need to remove these bolts before trying to pull it apart.
-Brian
-Brian
