tach wire?
Old Jun 17, 2002 | 09:28 PM
cw_civic's Avatar
Default tach wire?
Where is the tach wire for a 97 civic ex coupe. I've heard its blue and near the distrubetor, but i need more detail. Also, does the tach wire run inside the car anywhere? I rather tap into the wire inside the car, than tapping into it in the engine and having to run it thru the firewall.
[Modified by cw_civic, 6:29 AM 6/18/2002]
Old Jun 17, 2002 | 11:21 PM
STK B16's Avatar
Default Re: tach wire? (cw_civic)
under ur dash board should be a blue wire too. but its a pain. there is alot of just blue wires unde rthe dash.. or u can take out ur gauge cluster adn tap it into the blue on there.. Or.. out in ur engine bay.. look for a blue wire with a lil black plug to it.. it should have a blue tape.. wrap to it.. onto a wire harness. its on either side.. next to the fenders.. look around u will fine it.. its one Single blue wire .. or it would just be easy to grap it right there at ur distrubitor.. cuz there is only a black and blue wire.. so just tap it into the blue wire.. either way. it will work..
Old Jun 19, 2002 | 08:20 PM
t's Avatar
t
You can grab it at the ecu or at the cruise control brain.
Old Jun 19, 2002 | 08:21 PM
MurphDog74's Avatar
Default Re: tach wire? (t)
blue wire coming out of the icm
Mac Listo
Apr 22, 2008 06:03 PM
Mugen23cc
Nov 4, 2006 07:42 AM
heyitzspikey
Nov 29, 2005 05:23 PM
cw_civic
Jun 17, 2002 11:32 PM
projectcrx
May 15, 2002 10:36 PM
