tachometer
Re: tachometer (BlueIntegraBoy)
i got the same question toO ok.. i buy my techometer for some dude in the street... i dunno he 5 finger discount but i only pay 25 dollar for it everything work fine ...but i got problem at night ....no light coming on.cannot see at night ..what is the wire color?black,,red,,green,,,and were do i connect it to??? dim...
I tell doctors what to do
Re: tachometer (BucCivicSi99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BucCivicSi99 »</TD></TR><TR><TD CLASS="quote">i got the same question toO ok.. i buy my techometer for some dude in the street... i dunno he 5 finger discount but i only pay 25 dollar for it everything work fine ...but i got problem at night ....no light coming on.cannot see at night ..what is the wire color?black,,red,,green,,,and were do i connect it to??? dim...</TD></TR></TABLE>Do you guys have instructions? A lot of the time one wire is a power wire, one is a ground, and one needs to go to the negative terminal on the coil.
Re: tachometer (losopontes)
black wire- ground
red wire- power/ run to fuse box so it goes On/Off with ur key
green wire- goes to blue wire on distributor/ as i recall
white wire- dimmer
Modified by 1phatEG8 at 2:59 PM 10/25/2008
white wire- dimmer
Re: tachometer (esean93)
were is the good location for the dimmer switch or the dimmer fuse? cuz i try hooked up to my radio dimmer it don't work
Modified by BucCivicSi99 at 1:20 PM 10/25/2008
wat fuse u use depends on how many amps ur tach night light needs.probably 7.5 so use the interior light fuse.
allsho
04-30-2007 09:17 PM
esoterEK..
14
08-18-2004 12:44 PM
