Tach off
Tach off
Hey everyone. First off, I would like to thank everyone for even considering looking at my post. I have a 92 Civic VX and my tach is off by anywhere from 500 to 1000. It shows that my rpm's are are higher than what they really are. For instance, when I start it up, it says that I am at like 2500 but i know that I am way under that. Do any of you have any idea what could be causing this? Any help would be greatly appreciated.
Re: Tach off (Weezy11d7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weezy11d7 »</TD></TR><TR><TD CLASS="quote">Hey everyone. First off, I would like to thank everyone for even considering looking at my post. I have a 92 Civic VX and my tach is off by anywhere from 500 to 1000. It shows that my rpm's are are higher than what they really are. For instance, when I start it up, it says that I am at like 2500 but i know that I am way under that. Do any of you have any idea what could be causing this? Any help would be greatly appreciated.</TD></TR></TABLE>
Hello, does it start off at 2500, then drop down? To a regular idle or?
Re: Tach off (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">
Hello, does it start off at 2500, then drop down? To a regular idle or?</TD></TR></TABLE>
No, it ranges from 2000 to 2500, and i know my engine is not running that high. It never drops down anywhere in the range that it should be in. Sorry I wasn't clear the first time.
some tachs have little wires on the back that u have to cut one or the other for a 4 cylinder.....make sure u have the right one cut, check ground/power....make sure they are firm, what do you have your signal wire hooked up to?
No, it ranges from 2000 to 2500, and i know my engine is not running that high. It never drops down anywhere in the range that it should be in. Sorry I wasn't clear the first time.</TD></TR></TABLE>
if its stuck there, maybe check for a vacumm leak, or your fast idle valve is stuck open
Re: Tach off (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">
if its stuck there, maybe check for a vacumm leak, or your fast idle valve is stuck open</TD></TR></TABLE>
no his tach reads out 2-2.5k at an idle
Re: Tach off (EKEJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKEJ6 »</TD></TR><TR><TD CLASS="quote">
no his tach reads out 2-2.5k at an idle</TD></TR></TABLE>
sounds like he says his car starts up adn reads 2500rpms
You have the same problem as me, except mine reads about 1500 rpms too low. I hit the rev limiter at what the tach reads is 6000. I have an ex so of course its supposed to be 7200.
I havent had the chance to swap clusters, but to narrow it down, that would probably be the fastest way to find out what the problem is.
civickidd99
09-16-2003 07:51 AM
