Synchromesh Manual Transmission Fluid!
Old 03-27-2013, 06:32 AM
DankVI's Avatar
Icon2 Synchromesh Manual Transmission Fluid!
so today i want to change my manual transmisson fluid. i have a few different grinds in a couple gears. ive been doing some research and its all telling me to use GM synchromesh. but i cant find anywhere.
although, at my local Oreilly auto parts they sell a penzoil version of the same stuff. does it work just as good??
and how much would i need for a 1997 honda civic??
Old 03-27-2013, 06:40 AM
DankVI's Avatar
Default Re: Synchromesh Manual Transmission Fluid!
anybody know anything??
Old 03-27-2013, 06:45 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
you bumped it after 8 minutes?
have you tried google I bet that would work.
Old 03-27-2013, 07:08 AM
DankVI's Avatar
ya sorry about thatt. i did some research. i just want some feedback to my own question.. i just wanna know what people think of it here.
Old 03-27-2013, 10:31 AM
Oh look, I can change this
deschlong's Avatar
Try the Bob is the Oil Guy website too .... lots of very, very knowledgeable people on there.
Old 03-27-2013, 11:29 AM
kab00m's Avatar
You can use the Pennzoil brand. I've used it with no ill effects. You can find it for sure at Autozone or Oreilly Auto Parts (I prefer to shop at Oreilly).
Old 03-27-2013, 11:40 AM
ss_zoidberg's Avatar
The pennzoil is not the same as the GM synchromesh. The friction modified variant is the one people use to help with minor grinds
Old 03-27-2013, 11:41 AM
redtherocket's Avatar
You need to get GM Synchromesh w/ Friction Modifier
If you don't get the FM stuff, don't bother.
The fluid is actually made by Castrol, and they call it "Syn-torque".. But you cant just go get it.. Its sold by the barrel..
I can say I did notice a difference... Don't expect a miracle, but it does work good.
I especially noticed a huge noise reduction in reverse..
Its not much more expensive than Honda MTF... So I say go for it.
Old 03-27-2013, 12:27 PM
Ridin Dirty in Cali
dirty19's Avatar
Why would you need a friction modifier?
Running a LSD?
Old 03-27-2013, 12:31 PM
Friction modifier is not just a term used with limited slip fluids..... Its used in other things where friction disc's are not present.
Even Honda MTF has friction modified chemicals added...
Friction modifier makes things slippery... If you want to put it that way.
Old 03-27-2013, 07:41 PM
brettnahmann's Avatar
i have to disagree with the NEED to get friction modified.
when my 98 civic ex developed a 3rd gear grind over 4000rpm, i put 2 quarts of gm synchromesh (regular stuff, not fm). my grind disappeared as long as i didnt throw it into 3rd. it really helped out.
Old 03-28-2013, 06:41 AM
Seagull Management
94EG8's Avatar
Sometimes you can mask a minor grind with a different fluid, but it will come back eventually and it may cost more to fix at that point. What starts out a worn sleeve ends up being a completely trashed sleeve, scratched up hub and worn engagement teeth on the gear itself.
hawks85
20
07-19-2017 03:33 PM
TOO MUCH TORQUE
24
09-02-2011 06:24 PM
Ricen civic
06-05-2005 03:27 PM
letsstophere
05-04-2005 12:41 PM
Quick Reply: Synchromesh Manual Transmission Fluid!
