sway bar questions?
sway bar questions?
i have a 99 cx hatch i swapped the front lower control arms from a 93 civic si onto my hatch. i was going to use the swaybar from it as well but it doesn't seem to fit correctly it sits way too low, can i use these arms with the 99-00 si's front swaybar?
1 Post
Re: sway bar questions? (sohc_boy)
You need to use the front sway from a 99-00 Si.
You need to get..
The forks, the LCAs, the endlinks and the sway bar. Usually you can find it for like, $150-200
You need to get..
1 Post
as far as I know, you need to use the 99-00 Si control arms. I've never heard of anyone using anything else.... you could try and mount it up, but I seriously doubt it will work.
louie3252
08-31-2006 05:36 PM
