just swapped front LCA, to 99 si's and installed front lower sway. have a question + info
Hey i have a 98 dx hatch. i got some FREE 99-00 si lower control arms, mocked them up and installed them, i used moog bushings, and new sway bar down links. about 50 bucks wotha parts from the internet. worked out ok. i also had to use the 99-00 si shock forks. the weird thing is, visually when the cars on the ground the sway bar end links look like they point in funny directions. if you hold your hands out it would be like the one that gos threw the sway bar is pointing toward the engine, and down about 20 deg. should this be straight? the one goin thre the contorl arm is. just looks werid.
PhoBichNga
02-11-2002 08:15 PM
