sway bar?
sway bar?
hey i was juss wondering what kind of sway bars i should get for my 93 dx coupe and what size would be good...also do i need to change anything else to put them on or is it bolt on tia...
You could put on a GSR sway or get some aftermarket ones. However, you'll need to get different lower control arms that have threads for the endlinks. GSR lower control arms would work.
Re: sway bar? (B16b2b)
If you want to go with the oem honda swaybars then you will
need new control arms. Let me go find an old post of mine.
edit- I hate the search. I cant find a damn thing on there.
You will need to get control arms from:
front:
94+ integra
92-95 si/ex civic
(dont know my years) del sol
rear:
94+ integra
92-95 ex sedan
del sol dohc
Rear Swaybar sizes:
94+ integra lower models 13mm
94+ integra gsr 14mm
92-95 civic ex 4dr 13mm
Del sol I think its a 13mm
Front Swaybar sizes:
94+ integra lower models (i think) 19mm
94+ integra gsr 24mm
92-95 civic ex 4dr 19mm
Del sol I think its a 19mm
I hope that helps out some.
Modified by d15dude at 11:25 AM 7/8/2003
front:
94+ integra
92-95 si/ex civic
rear:
94+ integra
92-95 ex sedan
del sol dohc
Rear Swaybar sizes:
Re: sway bar? (Harpua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harpua »</TD></TR><TR><TD CLASS="quote">DOHC Del Sol Rear Bar is 15 mm (stock)</TD></TR></TABLE>
Are you sure?
A great way to check is to use an open end metric wrench.
Are you sure?
dj theoretic
04-15-2008 04:50 PM
4potnick
07-10-2006 12:09 PM
