LCA question
Re: LCA question (92civic_eg)
Here is some info I pulled out of searches to find what I needed for a 94 EX Coupe.
you could use LCA's from 94+ integras, civic ex sedan
if you want to do this right the first time, You may want to go with an Integra type r Usdm Rear sway! 22mm I believe and all you will need are lower control arms from a 94-00 gsr or ls, or 92-95 ex/si 's should have the control arms with hole for the sway bar endlinks. Then You can order your rear sway and Suspension reinforcement kit from Beaks products or Bsq kit. ( a must for mounting Itr rear bar on eg chassis or dc2 gsr/ls.
Front Swaybar Size
ex/si: 19mm
eg6: 21mm
gsr: 24mm
Rear Swaybar Size
ex/si: 14mm
eg6: 14mm
gsr: 14mm
Front Swaybar
If you are putting a front swaybar on any 92-95 civic (excluding ex/si)
you will need lower conrol arms from a integra, del sol, or ex/si civic.
Rear Swaybar
If you are putting a rear swaybar on any 92-95 civic (excluding 4dr ex)
you will need rear control arms from a integra, del sol, or a 4dr ex.
Beaks Kit
You do not need the beaks kit for the 14mm rear swaybars because they
should have the brackets on them that were made for the indents in your
frame. The type r had a flat rear frame, this is why you need the beaks kit.
Front Swaybar Size
ex/si: 19mm
eg6: 21mm
gsr: 24mm
Rear Swaybar Size
ex/si: 14mm
eg6: 14mm
gsr: 14mm
Front Swaybar
Rear Swaybar
Beaks Kit
4potnick
07-10-2006 12:09 PM
