Swapping speedo from clusters (CDM - JDM)
well, I have a CDM cluster with 135000KM on it, and a JDM with a cluster.
I basically want to swap the speedo from the CDM cluster because of the mileage and because it goes to 220 instead of 180.
if I take out the speedo form the CDM cluster and put it in the JDM one, will it work ? because the wire map from the back doesn't look the same.
CDM cluster:
CDM speedo :
JDM cluster:
wire map (JDM is on top):
Modified by Daniel_san at 12:27 PM 4/26/2004
CDM cluster:
CDM speedo :
JDM cluster:
Re: Swapping speedo from clusters (Daniel_san)
all you need to do is make sure it fits in there and the 3 sckrews make contact w/ the board.. i dont know if your speedo is gonna be off now cause it a different setup unless the speedo part can tell that what kind of signal its getting from the sensor but if you look at it, 80 is straight up almost on one and then 90 is almost straight up
not sure if the CDM and JDM is gonna be a problem, but
i also have a CDM CX cluster, and i swapped the speedo part into a USDM EX cluster and it worked fine.
give it a try it should work !
Re: Swapping speedo from clusters (ABK)
I know the whole cluster will work in my car. but I want to know if the speedo are interchangeable with the cluster, so that you can keep your mileage.
I had an EX cluster and swapped my speedo from my CX cluster and it work..im pretty sure it will work because it should be the same wiring and it doesnt hurt to try...its just 3-4 screws
Re: Swapping speedo from clusters (eg cookiemonster)
I'll try it. it better work, becasue I'm also gluing the plastic cover to the cluster, I can't stand that skwicking noise !! it's driving me crazy !!
this is for anybody that searches in the future,
it does work, so it seems that they all interchangeable
Modified by Daniel_san at 4:38 PM 4/26/2004
brutekiller787
21
12-02-2009 11:34 PM
95dxhatch
28
10-08-2004 08:28 AM
N1NjA TuRtLE
09-12-2002 07:15 PM
