swapping out my D16y7 for a D16y8
OK , I need to know.
The current y7 in my car is blown. If i direct swap for a y8, will the vtec work or will extra mods have to be done. Shop said it is direct bolt into my car, and vtec will work with no check engine lights or problems. Are they correct?
Last edited by Former User; 09-22-2011 at 12:41 PM. Reason: text edited for clarity
Re: swapping out my D16y7 for a D16y8
They said my ECU is the same one that comes with the y8,so if the engine comes with the harness everything will check out fine?
proper ecu for the head,IM and wire in the pins for the vtec oil pressure switch + vtec solenoid, or full harness and ecu
they said it comes wit the vtec selinoid and im pretty sure the wire harness ill call him back and ask him if the ecu is included if not how much to add because no sense to add vtec engine if the vtec isn't going to work that's like putting a celica engine in a supra i need a p2p or p28 ecu correct?
ok , the engine,wiring harness from a 2000 ex y8 engine, and a p2p ecu,and make sure the vtec selenoid is included sound good?
The Grumpiest
The solenoid isn't an option on a VTEC engine. Why are you asking like it is?
Go to another shop because this one doesn't seem to know what it's talking about.
The Grumpiest
What you NEED to do is go to the guy doing the install and ask him to make you a list of what he'll need and take that to the place you're buying the engine and make sure it fulfills the list.
yes i do know what it looks like , and i know where the engine is stamped i just havent done a swap on any of my cars yet till now and im trying not to get ripped if i knew everything about my honda i wouldent be signed up here or paying a mechanic to do the swap not to be rude im just trying to get everything prepared im sure alot of youl have done the same
Lasty K
27
11-01-2017 09:03 AM
