SWAPPING A B16A2 W/ LSD INTO MY EG!! WHAT AXLES, AND MOUNTS DO I NEED?
as topic says, swapping a b16a2 w/lsd into my eg and i am unsure what axles and mounts i need.... also, it comes with a cut harness, what does that mean and how do i hook it up
Re: SWAPPING A B16A2 W/ LSD INTO MY EG!! WHAT AXLES, AND MOUNTS DO I NEED? (2manycars2choose)
oh, that makes since
any b series harness will work?
Re: SWAPPING A B16A2 W/ LSD INTO MY EG!! WHAT AXLES, AND MOUNTS DO I NEED? (tallblondkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallblondkid »</TD></TR><TR><TD CLASS="quote">oh, that makes since
any b series harness will work?</TD></TR></TABLE>
With VTEC of course
With VTEC of course
Re: SWAPPING A B16A2 W/ LSD INTO MY EG!! WHAT AXLES, AND MOUNTS DO I NEED? (BlueIntegraBoy)
i was just reading some old treads about making my own harness, how do i do this, can anyone give me step by step instructions, thanks
Use the harness from your Civic, adding wires for vtec,knock sensor, and vtec oil pressure. You will also have to splice the distributor plug.
this should help http://tech.hybridgarage.com/tech/index.html
You also need the axles from a Del Sol vtec as weel as the mounts(or Integra mounts)
Re: SWAPPING A B16A2 W/ LSD INTO MY EG!! WHAT AXLES, AND MOUNTS DO I NEED? (hatchdrvr)
use your stock harness and add vtec...or try place racing or hasport..both places have full and sub harness's..for the axels go to a local autoparts store and get 1994 del sol dohc vtec 1.6 axels...do the same for mounts but buy the mounts used and get the prothane or energy suspension inserts ..the axels are like 60 bucks a pop
Re: SWAPPING A B16A2 W/ LSD INTO MY EG!! WHAT AXLES, AND MOUNTS DO I NEED? (Grip)
thanks alot for the help guys
also, what shift linkage can i use
Modified by tallblondkid at 4:16 AM 6/23/2004
dont forget to search
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Re: SWAPPING A B16A2 W/ LSD INTO MY EG!! WHAT AXLES, AND MOUNTS DO I NEED? (jdmsiR20)
i did search, and i got that, i just didnt like that diagram for some reason
any one else care to help
541Motorsports
05-12-2012 02:25 AM
