Swaped out cluster, now temp gauge doesn't work
I have and EG civic with a B20 in it. It came with a JDM cluster which has always worked perfectly. When I switched it out for an automatic transmission USDM cluster, the temperature gauge stopped working.
When I pulled it out, I saw that the JDM cluster was only hooked up to two ribbon cables that were at either end of it. I look at the USDM cluster and notice that it has 3 extra plug sockets that the JDM didn't have......a yellow and two green ones. I found a yellow plug on the dash harness that wasn't plugged in before so I plugged it in as well as the two ribbon plugs. But the two green plugs on the USDM cluster are empty. I tried it without the yellow plug too, but no dice.
Everything else on it works great.
Somebody told me that JDM clusters don't plug into USDM dash harnesses so I might have to switch out my dash harness. Another friend of mine said that the cluster is probably bad.
Any other ideas?
Thanks
Any other ideas?
Thanks
Re: Swaped out cluster, now temp gauge doesn't work
The yellow plug is for the srs light, pictures would help here. I can't recall ever seeing any blue plugs for the cluster, except on del sol's.
I've never had a problem with plugging a EG JDM or EDM cluster into any of my EG/EH USDM civic's.
i'm sorry....i edited my original post real quick but i guess i didn't catch it in time. i meant green, not blue.....
i have pics now, though
http://i1133.photobucket.com/albums/...p/IMAG0564.jpg
http://i1133.photobucket.com/albums/...p/IMAG0565.jpg
"and that's the game!"
mystery solved......thanks gang
i'll post elsewhere but just to close, does anybody in western washington want to trade my JDM cluster for a WORKING USDM cluster?
i also have a POS USDM cluster for sale now too!
do u have the big or small coolant gauge? i have spares of both and can send you just the coolant gauge for $30 shipped
949eg
05-29-2003 11:34 PM
