Swap, i think im set...what else do i need?
Ok, I ordered engine(b16) from IAS and hopefully will get it soon(some of you know the story behind that)
anyways I also ordered:
excedy clutch/flywheel combo
Kenji OBD2-1 harness
Prothane mount inserts
what else do i need? Radiator hoses im sure....what else? question is mostly for people who have ordered from IAS because from what I hear they include basically everything that you need.
thanks
thanks
Re: Swap, i think im set...what else do i need? (BigZ88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigZ88 »</TD></TR><TR><TD CLASS="quote">Ok, I ordered engine(b16) from IAS and hopefully will get it soon(some of you know the story behind that)
thanks</TD></TR></TABLE>
Radiator fluid, brake fluid, Honda MTF, oil, oil filter, timing belt, alternator belt, water pump, plugs, plug wires, and cam seal. Just basic maintenance items.
Re: Swap, i think im set...what else do i need? (ptran13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran13 »</TD></TR><TR><TD CLASS="quote">
Radiator fluid, brake fluid, Honda MTF, oil, oil filter, timing belt, alternator belt, water pump, plugs, plug wires, and cam seal. Just basic maintenance items.</TD></TR></TABLE>
got timing belt/water pump done. planned on the fluids (why brake fluid?) and why cam seals?.... damn forgot plugs and wires. GRR
Cam seals always seem to leak just order a billet one like str (not sure if anyone else even makes them) and youll be set also would do a distributor cap and rotor right away too.
Re: Swap, i think im set...what else do i need? (zigs)
well IAS said they were replacing some seals, maybe those were the ones. I hope so in that case. So, i should be pretty good then huh?
whole9
03-31-2007 03:23 AM
