Swap help
Swap help
I got a 1992 Honda Civic DX Hatchback stock 1.5 L D15 engine non vtec 4 cylinder auto tranny. Swapping a 1.6 L D16 VTEC auto tranny. I got the P28 ECU and because my car is a 1992 the wiring for the ECU is already hooked up. My problem is I have the stock non vtec engine harness on the car. How do I run the plugs for the Vtec and pressure sensor? I didnt get the plugs for the vtec solenoid or the pressure sensor either is there a way to bypass them or where can I buy them? Do I run a wire from the VTEC Solenoid and the pressure sensor to the shock-tower where it connects with the ECU and connect the wires to the opposite side of the connector? Where can I get the pins for the plug? Thanks for your time
Re: Swap help
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
92accordh22a
12-16-2006 07:21 AM
labatia
18
05-19-2004 06:12 PM
