SUSPESION PROB???
Old 06-16-2008, 03:51 AM
puthuff's Avatar
Default SUSPENSION PROB???
i have a 00 ex cpe and im gettin a metal to metal sound from the front when hitting bumps or driving in gravel. i put new poly urethane sway bar bushings on and it helped out alot but when putting the bushings on seen the stab links were worn so i put them on and now noise is just as bad? please help
Old 06-16-2008, 08:23 AM
hondapwr's Avatar
Default Re: SUSPENSION PROB??? (puthuff)
poly bushings can make a high pitch squeal that could sound like metal on metal. If you had metal on metal scraping somewhere on your car you would see the marks. You probably just need to lube the poly bushings.
Old 06-16-2008, 08:32 AM
Fullthrottle297's Avatar
how hard are you hitting the bumps
your bump stops in your shocks could be gone
Old 06-16-2008, 08:39 AM
puthuff's Avatar
Default Re: SUSPENSION PROB??? (Fullthrottle297)
not hitting bumps real hard but when driving in gravel it sounds like somthing is loose and gonna fall off my car
Old 06-16-2008, 08:40 AM
puthuff's Avatar
i have it lowered with kyb gr2 struts and hr sport springs
bbbsti
Honda CR-V & Element
10
11-26-2010 02:54 PM
agent1471
03-16-2007 04:45 PM
Serenity Now!
03-02-2007 02:06 AM
fluxion
11-24-2003 12:24 PM
battyx
03-19-2002 08:36 AM
Quick Reply: SUSPESION PROB???
