Sunroof binds against roof on 95 Civic EX
Using the sunroof tool, the sunroof opens with minor difficulty, until it starts tilting, at which point it binds into the roof and stops moving. The track doesn't look well lubricated, but I don't think that's the problem. Anyone have similar problems? Any advice is appreciated. Thanks friends.
Oh look, I can change this
Re: Sunroof binds against roof on 95 Civic EX
Correct. IIRC, the threaded cables that operated the movement of the sunroof were stripped. A new sunroof assembly was cheap at the junkyard. Maybe $30. Your existing roof glass can be reused but consider having a replacement on hand just in case. Spare parts are not a bad thing. (Note also that there were small changes to the design of the glass in 92 vs 93-95 ... all are fwd and backward compatible.)
The service manual (google it to find it) has all the instructions step-by-step that you need to follow. It is your bible. Study it.
You will need the correct Allen bit to move the roof glass manually and possibly also to remove the glass. Practice on your own vehicle before you go to the junkyard so you have all the right tools....
Be CAREFUL. 30-year-old plastic bits have a tendency to break. Follow my DIY links to find a list of junkyard tools to bring with you.
Here is a useful post: https://honda-tech.com/forums/honda-...oblem-3118716/
And here is another which I encountered after installing the replacement sunroof assembly: https://honda-tech.com/forums/honda-.../#post50971208
Sweet. I found it and printed it out at UPS (I like it in print and it was 1200 pages). Another question for you: the manual covers EG and EK, though I don't think it covers EJ1, which is my chassis. Will this matter, or will they be okay? I'm thinking worst case I can just print the different EJ1 parts and put them in place of the EG/EK ones. What do you think?
Manual does NOT cover the 96-00 Civic generation. Technically correct that it does not cover the EJ1 since the downloaded manual is for a 1992 Civic and the Coupes came out in 1993.... But there is so much similarity between the chassis types of the same generation that in many cases it is not a problem. Your sunroof shares the same design as the Hatchback. Sedan sunroof is quite different.
Alrighty, just took out the moonroof today, the problem was exactly what you said: stripped cables. So, my options are to find one in the junkyard, or buy one from the stealership (if they still have them, that is). Which option do you think is better, or is there one I've overlooked? And thanks for all the help, man.
Found one at a local junk yard, fit it into my car, works a lot better than the original. Some things I found interesting: the orange stuff wrapping the threaded cables is made of plastic, and when I blasted the exposed cable with brake clean to get the old grease off, and the orange plastic started to fray so I stopped; for some reason, neither my overhead light not the trunk light work. Probably some wiring that must have come loose or something when putting back the headliner; the moonroof works pretty great, except usually, the first time I open it, it needs a little push up on the rear end of it to get going, but after that, it can go out all the way and in all the way without any help. I'm thinking the tracks just need some more lubrication, or it could be a glass height issue, either way not too bad. Thanks for the help, man. It was spot on.
Premium Member
If it's getting stuck, it's a glass adjustment + lubrication issue. I use white lithium grease to get things going after adjusting.
Both the trunk lamp and the overhead light run off the same wire at the fuse box. It could be that you've blown a fuse.
Fantastic420
10-07-2009 05:46 PM
