Front Sway Bar or Bar Traction in Civic 95
Hello colleagues, I have a 95 civic hatch, I want better suspension, and install a rear sway bar and subframe. My problem is on the front, I have the option to purchase an Integra Type R 25MM Front Sway Bar and Bar Traction I want to buy both. My question is, I can install both? If I can only install one, which is better?
Re: Front Sway Bar or Bar Traction in Civic 95
You sure my friend would be a great waste of money if I buy both and I can not install, I do not know much about mechanics, thanks. You seen the two bars installed in a car?
If you look where the traction bar bolts, it bolts if front of the LCA.
It uses the one of the bolts on the control arm.
They are both basicly doing the same thing, the traction bar just won't give you understeer, where the sway bar will.
do some research first. google it look at images I bet in 5 mins you'll find a pic to prove my point. don't be lazy
typeeg
09-26-2003 03:53 PM
