What brake booster can i use, 94 EJ. ABS delete
Old 02-14-2017, 07:11 PM
B_Swapped93's Avatar
Default What brake booster can i use, 94 EJ. ABS delete
94 EJ LX w/abs. I've got all 4 lines/prop valve and master cyl from a non abs LX, i'm told I cant use the ABS BB that's on there?. Will this new BMC not fit the current BB, I've gotten everything from the dealer so far. But i'm not spending $500 CAD for a non abs booster. Can I use the ITR one or the RS(no abs) BBs i'm lost here, everything has been cut and dry so far.
thanks.
Old 02-15-2017, 05:58 AM
civic402lx's Avatar
Default Re: What brake booster can i use, 94 EJ. ABS delete
U can use the one from the rs it will bolt up to the 95 BMC and the lines will line up and bolt in with no mod. The itr won't bolt up to your bmc, bolt pattern is opposite.
Old 02-15-2017, 06:55 AM
Premium Member
94 Civic Si's Avatar
Why are you deleting ABS?
Old 02-15-2017, 04:48 PM
Thought everyone said you had to ditch the ABS brake booster? I have the brake master from the LX without ABS, my question is, will the LX non-abs BMC bolt up to the ABS booster. Or is the non abs booster the SAME as the ABS booster, they had different part numbers.
Useless on a 638whp turbo K20.That I trailer to races.
Old 02-16-2017, 07:52 AM
Premium Member
Ah, I will take the old ABS parts you delete if they are in working order...
ls19integra95
11-22-2007 09:35 PM
Chim Chim
03-31-2007 07:36 AM
highcomp
04-15-2004 07:36 PM
Quick Reply: What brake booster can i use, 94 EJ. ABS delete
