Stuck in 2nd gear....
I just swapped a Y8 tranny in my car two months ago. Well I was trying to get on the interstate and I was slamin gears, and once I went to shift into 3rd it didn't want to go so I figured I'd just let off and take it easy... Well I tried shifting it again and it won't go into any gear its just stuck NEUTRAL (but really 2nd), and once I turn the car off it will I can go through my gears 1st - reverse BUT not 2nd!!! WTF?!
Thanx for ANY input!
btw, its a stock d16z6 turbo, with a Y8 transmission....
Re: Stuck in 2nd gear.... (soundpsych)
Good going, you broke your transmission.
Needs to be either replaced or rebuilt
"slamming" gears will bring that sort of thing upon you
Re: Stuck in 2nd gear.... (97Ej6mike)
dang.... Well I wasn't really SLAMMING gears, but I was taking them out to about 6500 rpms... Well if it turns out this transmission is shot I guess i'm de-boosting it and putting EVERYTHING back to OEM.
Damn and I thought Y8 transmission were strong....
Re: Stuck in 2nd gear.... (The Dirty EJ1)
Just find a d series trans and replace your forks synchros and bearings you'll be fine the transmission is strong but selector forks are not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundpsych »</TD></TR><TR><TD CLASS="quote">transmission is strong but selector forks are not.</TD></TR></TABLE>
true that, but I thought thought the reason why everyone (including myself) would upgrade to the Y8 is because of the STEEL fork instead of the aluminum fork in the Z6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Dirty EJ1 »</TD></TR><TR><TD CLASS="quote">
true that, but I thought thought the reason why everyone (including myself) would upgrade to the Y8 is because of the STEEL fork instead of the aluminum fork in the Z6.</TD></TR></TABLE>
Its actually the other way around i believe, the Z6's are supposedly much more reliable than the Y8 ones are.
BTW, why would you thing to 'de-boost' your car and 'return it to OEM'?
Get a Z6 tranny, or rebuild the y8, dont waste any time taking the turbo off, thats not the problem, your transmission is.
Drive it like a normal car, and you can expect a normal lifespan out of your next tranny.
No, i'm 99% sure the Y8 is the "strong" transmission....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
tranny.</TD></TR></TABLE> Because this will soon to be my 3rd tranny in the car since I boosted it (3 months ago) I'm just going to turn it back to OEM stock specs, makes it clean as fukkk AND I smell k-series in the future.
Modified by The Dirty EJ1 at 11:56 AM 9/2/2007
