STRUT BAR BOLT SIZE
STRUT BAR BOLT SIZE
hey, kinda of a newbie here. juss please dont flame. Anyway, i got a OEM SI STRUT BAR for my 95 civic ex coupe. I want to know how to install this. What size nuts or bolts and what type do i get? also, any suggestions as to how to get this perfectly installed? thanx
Re: STRUT BAR BOLT SIZE (civicboi950)
i think you need a 10 or 12. Just take off the two bolts on each side of the strut tower and fit on the bar then put the bolts back on. It will take 5min.
Re: STRUT BAR BOLT SIZE (sa21199)
He said OEM SI strut bar which probably means the 99-00 coupes. The strut bar doesn't actually go over th strut bolts. It could be the same size bolts but iono ...
Re: STRUT BAR BOLT SIZE (maztur)
if it's the type r strut bar you need to drill holes right next to the strut tower. Place the bar in the engine so it's feet sit right on the frame. mark then drill holes. Then you need to bolt it on.
As a side note I bought one of those bars and I decided to return it. I prefered the ease and look of the ones that bolt directly to the struts.
Re: STRUT BAR BOLT SIZE (Grimm)
95 EX coupe should already have the holes drilled in for this bar. TypeR and Si and GSR bar all bolt into the same place. Sorry I don't know what size bolts they are I purchased my bar and came with the bolts. My 93 coupe had the holes, I just had to pull a little plastic plug out.
apalmucci
22
03-23-2011 01:36 AM
