Strange WINE in first gear(louder than normal), and trouble shifting???
Old 06-17-2004, 10:19 AM
stehigs321's Avatar
Default Strange WINE in first gear(louder than normal), and trouble shifting???
Hey i have a 96 civic ex with a 98 B18C1. Just recently, like today, first gear has a louder wine than ive heard it ever do, and going from 5th to fours is very hard, doesnt want to get into any of the gears. But when i get it into gear, i put the clutch in and take it out of gear, then when i take my foot off the clutch i hear a click of some kinda that kind of sounds different than usual. I checked my clutch fluid and it seemed ok, and have no other idea except that one. what else could it be?? would the input shaft bearing being bad make it hard to get the car into gears?? what should i do when i haver my tranny off to put my clutch in?? should i just bring my whole tranny to a tranny shop?? they wont charge for labor on taking it out of my car, they just have to tear it down.
Modified by stehigs321 at 7:41 PM 6/17/2004
Modified by stehigs321 at 8:09 PM 6/17/2004
Old 06-17-2004, 10:24 AM
Global Moderator
Jimmy's Avatar
Default Re: Strange WINE in first gear(louder than normal), and trouble shifting??? (stehigs321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stehigs321 &raquo;</TD></TR><TR><TD CLASS="quote">Hey i have a 96 civic ex with a 98 B18C1. Just recently, like today, first gear has a louder wine than ive heard it ever do, and going from 5th to fours is very hard, doesnt want to get into any of the gears. I checked my clutch fluid and it seemed ok, and have no other idea except that one. what else could it be??</TD></TR></TABLE>
Sounds like Input shaft bearing
Old 06-17-2004, 10:36 AM
stehigs321's Avatar
Default Re: Strange WINE in first gear(louder than normal), and trouble shifting??? (Jimmy)
is that an easy fix?? it just so happens that i am about to install a new clutch and flywheel. I got an ACT clutch kit that came with some bearings. are either of those the culprit. i have noticed lately that i need a new clutch, could that just be the problem??
Old 06-17-2004, 10:39 AM
stehigs321's Avatar
please help i can barely get it into gear???
Old 06-17-2004, 10:40 AM
Global Moderator
Jimmy's Avatar
No the bearing that came with your ACT clutch is your throwout bearing and your pilot bearing.
I've never fixed an input shaft bearing i know it requires tranny removal.
Pm ''bauleycivic'' or ''ricey mcricerton''
Old 06-17-2004, 10:46 AM
stehigs321's Avatar
Default Re: (Jimmy)
if anyone can help please do
Old 06-17-2004, 10:58 AM
93CivicSI's Avatar
Input shaft bearing
93CivicSI's Avatar
Default Re: Strange WINE in first gear(louder than normal), and trouble shifting??? (93CivicSI)
do a search on the topic - there are a couple of threads that explain how to do it....
Old 06-17-2004, 11:07 AM
stehigs321's Avatar
well , see, that click sound only happens once, right when the clutch gets released after i have taken it out of gear. understand?? but how could this have happened? i havent driven it in like 3 days. Would you guys recommend having a shop fix this??would the input shaft bearing make it hard to get into gears???what should i do when i haver my tranny off to put my clutch in?? should i just bring my whole tranny to a tranny shop?? they wont charge for labor on taking it out of my car, they just have to tear it down
Old 06-17-2004, 11:25 AM
stehigs321's Avatar
bump, someone has gotta know
Old 06-17-2004, 11:34 AM
stehigs321's Avatar
bump please, i got no ride cause i dont wanna drive on it like this.
Old 06-17-2004, 12:13 PM
FeatherWeight
Guest
Posts: n/a
change your tranny fluid.
If the problem persist, check whats stated from the members above.
Old 06-17-2004, 08:17 PM
stehigs321's Avatar
Default Re: Strange WINE in first gear(louder than normal), and trouble shifting??? (FeatherWeight)
Can these easily be changed by me? how hard is it ripping apart the tranny and changing the bearings? I will have the tranny off next week for a new clutch and flywheel that is going in.
Old 06-17-2004, 08:38 PM
stehigs321's Avatar
bump
Old 06-17-2004, 09:07 PM
North_Texas's Avatar
Sounds like your freaking out a little too much and it's making everything hard to understand from you. You could just bleed your clutch fluid. But I'm sure its probably your Input Shaft Bearing. I'm sure if you search on this part or search DIY tranny build, something in that area and PM the guys that have worked on this particular part and you should get many of your questions, answered.
Old 06-17-2004, 09:47 PM
Risky Business
BauleyCivic's Avatar
Default Re: Strange WINE in first gear(louder than normal), and trouble shifting??? (DixieRedneck)
https://honda-tech.com/zerothread?id=596873
read...pm me if u have any questions...
Old 06-17-2004, 10:04 PM
stingray2772's Avatar
Default Re: Strange WINE in first gear(louder than normal), and trouble shifting??? (BauleyCivic)
i redid an i.s bearing in a d-series, it was pretty easy, just remember how everything goes
Old 06-18-2004, 06:19 AM
stehigs321's Avatar
Default Re: Strange WINE in first gear(louder than normal), and trouble shifting??? (stingray2772)
ok, can i just pick up new bearing at local honda dealers?? is there anything else i should change while im in there??
Old 06-18-2004, 08:40 AM
just kind of check the other large bearings in there, i replaced a couple...
also when i took it to the dealership, they said if it wasnt in stock theyd simply visit a nearby bearing place and order it there, and charge full price, so we went there, he ordered the bearings, and one was a special order bearing, something about numbers on the back you usually dont use, but we finally got it and it worked great
Old 06-18-2004, 10:33 AM
stehigs321's Avatar
so i can just carry my tranny to honda and they will rip it apart for me?? how much do you think they will charge for that? or should i just bring it to a place that does bearings?? what does that service run for?? i dont think i could do that on my own.
Old 06-18-2004, 10:40 AM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stehigs321 &raquo;</TD></TR><TR><TD CLASS="quote">so i can just carry my tranny to honda and they will rip it apart for me?? how much do you think they will charge for that? or should i just bring it to a place that does bearings?? what does that service run for?? i dont think i could do that on my own. </TD></TR></TABLE>
not sure if you can do this... atleast in socal.. &gt;&gt;&gt;no honda dealership rebuids trannys let alone opens them up.. &lt;&lt; its too much work for them. takes too long for a turn around. they just have you pay for a rebuilt one. with your trade in...
just open it up and see what you have...
Old 06-19-2004, 06:01 AM
stehigs321's Avatar
Default Re: Strange WINE in first gear(louder than normal), and trouble shifting??? (cxSHOE)
well if i have any probs who should i take it to?? al local tranny shop? will they just take the tranny and change the bearings?? how much will this cost to have them do? the tranny will already be off.
Old 06-19-2004, 07:24 AM
91civicDXdude's Avatar
it could possibly be just the throwout bearing. If it makes the noise when you release the clutch pedal
zracer240
07-21-2005 12:15 AM
socki18
01-10-2005 11:21 AM
Synergy001
17
12-08-2003 10:07 PM
tilt
10-07-2002 01:22 PM
Quick Reply: Strange WINE in first gear(louder than normal), and trouble shifting???
