stock d16zc sohc vtec turbo
I'm not Rick!
Re: stock d16zc sohc vtec turbo
10lb(it will last you awhile)....dpends on your budget too. more boost will call for quality parts
sissies will tell you 8 or less. but ive seen around her stock Dseries go to 15lbs all day long daily driving. all in the tune though
i new a guy with a bone stock d16z6 ex model with 150,xxx with just a built head and arp head stunds with a t25 turbo runing 15psi, he tryed to break the thing, couldnt do it, untill he took her on the highway one day really pissed off and ran her super lean, then dropped her from 5th to 3rd and out came pistions ,oil, an smoke. gota love hondas .
If you go ANY HIGHER than 9PSI, I strongly suggest upgrading to ARP headstuds.
Z6 tend to have head lift at around the 11-12PSI mark, but it is hit'n'miss.
Some will lift at 10PSI, others will go up to 18PSI.
Me personally, I have been running 10PSI on a stock Z6 w/OEM headstuds no problem.
Also, the OEM Honda MAP sensor is good to 11PSI, so if you wanna go higher, you're going to need an aftermarket pressure/MAP sensor.
Hope this helps.
Hope this helps.
umm yeah, i just ran my d16 turbo del sol, with a Stage 2 crower cam, ARP headStuds, .030" over Cometic Headgasket and stock block and a little over 20,xxx mi on it, at around 10-12lbs of boost, and put roughly 4 holes through my block and had piston/connecting rod/block parts all over the road, i would be careful. I blew out my block at around 4-5k rpm's going roughly 70
Anyway, I say go for 8psi. lol.
-Tony
what is a good compression ratio for a d16 for a lot of boost? i have been told too low a compression and you will have no power till it spools up. any help is appreciated
ek9child
04-09-2006 01:53 PM
