still need to retard timing 2 degrees
Old 09-21-2008, 02:20 PM
chickenwing's Avatar
Default still need to retard timing 2 degrees
I was trying to time my y8 but the distributor would not turn more and ended at about 10 degrees instead.
It seems that the distributor bolt slot was preventing the me from turning it more so I dremeled the hole like 2mm in each hole.
now I have it timed at 12 degrees but I cannot adjust my idle.
Old 09-21-2008, 02:58 PM
The Lobster's Avatar
first why did you do this?
second what is your setup?
third your tbelt might be on right or you have the cam/crank timing off.
this seems like a bigger problem then drilling out your dizzy....
Old 09-21-2008, 03:55 PM
Default Re: (The Lobster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">first why did you do this?
this seems like a bigger problem then drilling out your dizzy....</TD></TR></TABLE>
I was able to only get 10 degrees and unable to get the specified 12 degrees. Since the dizzy could not turn anymore I removed a few mm of material so I could get the 2 degrees more.
D16Y8, competition cam, competition hd springs, competition titanium retainers, 4-2-1 headers, 2.5 piping out to a CTR muffler, alumnium flywheel, 6 puck clutch, gearspeed rebuilt transmission.
The timing belt is installed correctly and timed with the cam and crank.
I'm having major stalling at stop signs and by just pressing in the clutch changing gears.
bopbop93030
02-24-2009 02:57 PM
allnaturalb16
21
08-14-2007 08:57 PM
brusk13
01-11-2006 07:01 PM
sed6
06-05-2004 04:04 AM
Quick Reply: still need to retard timing 2 degrees
