Steering Wheel Shakes Under Braking After Accident...
Old 10-07-2004, 01:14 PM
Risky Business
BauleyCivic's Avatar
Default Steering Wheel Shakes Under Braking After Accident...
So my brother ran into a curb the other week and blew out his right front tire. We got a new wheel, 4 new tires, had an alignment done, and had all of the wheels balanced, and now the steering wheel shakes under braking and pulls to one side.
I'm assuming something in the suspension is broken or bent, I just need to know what to look for...control arms? tie rod? axle?
All input is appreciated. Thanks
Old 10-07-2004, 02:36 PM
93Civac's Avatar
Default Re: Steering Wheel Shakes Under Braking After Accident... (BauleyCivic)
If something was bent id think they would have seen it when they did the alignment, but its possible they missed something. Does it pull at all when your not braking? I was thinking that the vibration may be caused by a warped rotor, or the pads could even be cracked. Other than that I have no ideas.
Old 10-07-2004, 02:44 PM
nonsense's Avatar
tie rod end?
caliper mounting bracket?
wheel bearing?
Old 10-07-2004, 02:53 PM
CoolKat's Avatar
Default Re: Steering Wheel Shakes Under Braking After Accident... (93Civac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac &raquo;</TD></TR><TR><TD CLASS="quote">If something was bent id think they would have seen it when they did the alignment, but its possible they missed something. Does it pull at all when your not braking? I was thinking that the vibration may be caused by a warped rotor, or the pads could even be cracked. Other than that I have no ideas. </TD></TR></TABLE>
Old 10-07-2004, 03:31 PM
pip9's Avatar
Default Re: Steering Wheel Shakes Under Braking After Accident... (CoolKat)
Dustin, same thing happened with my 96 civic. I had an accident and now my car vibrates pretty badly, mostly when stopping. I checked my brakes the other day and they are getting pretty low so I bought some new oem pads and i'm going to replaced them sometime soon.
If its just when u brake its most likely just warped rotors.
On another note though my brother hit a curb with his civic and damaged the pass side suspension parts. It ended up being around $1600 to fit everything.
where did u get all this work done at?
Old 10-07-2004, 05:12 PM
Risky Business
Default Re: Steering Wheel Shakes Under Braking After Accident... (pip9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pip9 &raquo;</TD></TR><TR><TD CLASS="quote">
where did u get all this work done at?</TD></TR></TABLE>
A friend who works at a shop...
Old 10-07-2004, 05:26 PM
hayabusa160's Avatar
2 of my friends did the same thing.
gayest thing about this is you cant find the part thats bent it is so hard to tell.
you cant just look at it and say oh damn its bent its off by so little that the eye cant pick it up.
check the sub frame to see if it got bent alittle.
both of my friends their sub frame got tweaked a bit and caused this shitty feeling under braking.
Old 10-07-2004, 06:33 PM
Fergy82882's Avatar
It might be the rotors but my best advise is to have a shop take a look at it. You can damage a lot from just hitting a curb
Old 10-08-2004, 04:49 AM
EE_Chris's Avatar
Default Re: Steering Wheel Shakes Under Braking After Accident (Fergy82882)
Shocks
Tie-rods
I curbed my car too, 2 times actually, and the shocks took the hit.
Old 10-08-2004, 04:57 AM
hondainspired's Avatar
Default Re: Steering Wheel Shakes Under Braking After Accident (EE_Chris)
i would think if its shaking under breaking only... then your lookin at warped rotors.... means the rotors prob. got to hot when he was trying to break to not hit the curb... change the pads and rotors out clean the caliper slider pins up real nice and grease them like you grease ur monkey when ur tryin ta have butt sex...
Old 10-08-2004, 05:04 AM
TurboEH2's Avatar
Default Re: Steering Wheel Shakes Under Braking After Accident (hondainspired)
my buddy did this in his element (while playing in the snow) and it bent the lower control arm. u couldnt really see it, but he replaced it and he also found the tie rod ( i think ill get him to come in here and give u the in depth) was fucked also.
Old 10-11-2004, 09:14 PM
dcsports's Avatar
Default Re: Steering Wheel Shakes Under Braking After Accident (LSturboEH2)
i vote lca
lildragon'07
13
06-02-2010 08:31 AM
dc2gsr96
11-06-2006 08:26 PM
Turbo_Mike
Suspension & Brakes
10-19-2005 09:29 AM
ceasar of mgineering
05-06-2004 10:11 PM
B-B-K
17
03-30-2004 11:46 AM
Quick Reply: Steering Wheel Shakes Under Braking After Accident...
