Starting up problem on eg!!!
My Eg will not start up unless i put a screw driver on the starter bolt and connector. And right now i got it bootleg with a switch and two wire's in the bolts anyone knows why this would happen?
Re: Starting up problem on eg!!! (HondaKid936)
Starter relay(i know tegs have them, im think all cars do though, lol)? Key cylinder? Checked your grounds? Those are all i can think of.
Re: Starting up problem on eg!!! (z6hatchboy)
Ok i checked the ground all the ground and there good and where's the starter relay?? Under the hood or dash.
clutch switch - detects if your clutch pedal is depressed or not. These tend to go dead fairly often on older Hondas (at least they have for me)
Re: Starting up problem on eg!!! (hades)
Ok the problem is on my car i just on his computer at the time and i'll check it but do they just go out all of a sudden like mine did??? Mine didnt even show any problems? But thanks for the help ill try to see if thats it!
MistahJuice
01-30-2012 11:30 PM
