Starting up problem
Starting up problem
Replaced my clutch and pressure plate put everything back together checked the starter after I tried staring it and noting happened nor the cluster or radio turn on however my head rest light lights up can somebody help plz
Re: Starting up problem
did you forget your ground on the transmission? or were you lazy and left battery disconnected and probably shorted power wire while taking starter off.
As stated check your transmission ground to the chassis to make sure it’s tight and getting good connection. Also make sure you signal wire is connected to the starter ( that little terminal that goes on the small connector on the starter.
If tranny ground is good. Then check your fuse for the starter relay.
If its good then then check your starter, get a wire long enough to jump from the positive on the battery to the bigger connector with the nut that screws on top of the starter ( warning: just tap wire on the terminal DO NOT HOLD IT ON THERE for long or you’ll fry the starter )
if it turns over then your starter is still good and start troubleshooting your wire connections and ignition switch and top clutch switch.
wes7side5o
03-22-2007 05:07 PM
